Soil and Rock - Bulk Factors
Soil or rock from the borrow expands when dropped on the lorry or the landfill - or stockpiled. One cubic from the borrow does not translate to one cubic dump.
Bulking or swell factors for some materials:
| Material | Density at the Borrow 103 (kg/m3) | Bulking (Swell) Factor (%) |
| Basalt | 2.4 - 3.1 | 75 - 80 |
| Clay | 1.8 - 2.6 | 20 - 40 |
| Dolomite | 2.8 | 50 - 60 |
| Earth | 20 - 30 | |
| Gneiss | 2.69 | 75 - 80 |
| Granite | 2.6 - 2.8 | 75 - 80 |
| Gravel, dry | 1.80 | 20 - 30 |
| Gravel, wet | 2.00 | 20 - 30 |
| Gravel, wet w/clay | 50 - 60 | |
| Limestone | 2.7 -2.8 | 75 - 80 |
| Loam | 15 - 25 | |
| Quartz | 2.65 | 75 - 80 |
| Rock | 40 - 80 | |
| Sand, dry | 1.60 | 20 - 30 |
| Sand, wet | 1.95 | 20 - 30 |
| Sandstone | 2.1 - 2.4 | 75 - 80 |
| Slate | 2.6 - 3.3 | 85 - 90 |
| Soil | 1.2 - 1.6 | 20 - 30 |
- 1 kg/m3 = 0.0624 lb/ft3
Example - Swell Factor
After excavation of 300 m3 clay with bulking factor 40% - the clay swells to
(300 m3) (100% + 40%) / 100% = 420 m3
in the dump.
Angles of Repose
Tipping or dumping angles for common materials like ashes, sand, earth, shingles and more.
Conveyors - Maximum Inclination vs. Product
Maximum conveyor inclination slopes for typical products.
Densities of common Products
Densities of common products - Imperial and SI-units.
Dirt and Mud - Densities
Densities - pound per cubic foot and kilograms per cubic metre - of dirt and mud.
Ditch Filling Materials - Densities
Weight or density of ditch filling materials.
Excavation Slopes
Calculating excavation slope.
Geological Time
Geological periods and time scale.
Gravel - Cover Area
Gravel aggregate covering area.
Porosity
Volume not occupied by solid material.
Soil - Earth Weight and Composition
Typical weight and composition of soil.
Solids - Densities
Densities of selected solids.
Stockpile Volumes
Volume of natural stockpiles - cubic feet, yard, metre and decimetre.
Stones - Weight and Strength
Weight and strength of sandstone, granite, limestone, marble and slate.
Trench Excavation
Estimate trench excavation - online calculator.
Underground Pipes - Earth Pressure
Pressure acting on underground pipes due to weight of soil and transport.
