Dirt and Mud - Densities
Material | Density - ρ - | |
(lb/ft3) | (kg/m3) | |
Dirt, loose dry | 76 | 1220 |
Dirt, loose moist | 78 | 1250 |
Clay, dry | 100 | 1600 |
Clay, wet | 110 | 1760 |
Gravel, dry | 105 | 1680 |
Gravel, Wet | 125 | 2000 |
Limestone | 160 | 2560 |
Loam | 80 | 1280 |
Mud, flowing | 108 | 1730 |
Mud, steady | 115 | 1840 |
Rock, well blasted | 155 | 2480 |
Sand, dry | 97 | 1555 |
Sand, wet | 119 | 1905 |
• Densities
Density Converter
Ditch Filling Materials - Densities
Weight or density of ditch filling materials.
Earth Pressure Acting on Basement Walls
Calculate lateral earth pressure acting on basement walls.
Gravel - Cover Area
Gravel aggregate covering area.
Minerals - Densities
Densities of minerals.
Soil - Earth Weight and Composition
Typical weight and composition of soil.
Soil - Electrical Resistivity
Types of soil and resistivity.
Soil and Rock - Bulk Factors
Solids and Metals - Specific Gravities
Specific gravity for common solids and metals like aluminum, asbestos, brass, calcium and many others.
Specific Heat of Common Materials – Engineering Reference
Trench Excavation
Estimate trench excavation - online calculator.
Underground Pipes - Earth Pressure
Pressure acting on underground pipes due to weight of soil and transport.
