Thermal Expansion - Superficial i.e. Area
The amount by which unit area of a material increases when the temperature is raised by one degree is called the coefficient of superficial (i.e. area) expansion. Superficial thermal expansion can be expressed as
dA = A0 γ (t1 - t0)                                 (1)
dA = change in area (m2)
A0 = initial area (m2)
γ = superficial expansion coefficient (m2/m2K)
t0 = initial temperature (oC)
t1 = final temperature (oC)
Online Superficial Thermal Expansion Calculator
Change in area (dA): (m2)
Final Area (A1): (m2)
In general the superficial temperature coefficients can be approximated to
 γ  ~= 2 α
α =  linear temperature expansion coefficient (m/m K, m/m oC)
Linear Temperature Coefficients - α - of some common metals
  • aluminum : 0.000023 (m/m oC)
  • steel: 0.000016 (m/m oC)
  • copper: 0.000017 (m/m oC)
Thermodynamics
Linear Thermal Expansion
Liquids - Volumetric Expansion Coefficients
Volumetric - or cubical - expansion coefficients for common liquids.
