(m3/h)
Product | Smell | Limit (mg/m3) |
Ammonia | Sticking | 0.5 |
Carbon disulphide | Aromatic, little sticking | 2.6 |
Chlorine | Sticking | 0.06 |
Chlorate phenol | Medical | 0.18 |
Ether | Geranium | 0.069 |
Prussic Acid | Bitter almond | 1 |
Hydrogen sulphide | Rotten egg | 0.26 |
Ozone | Little sharp | 0.096 |
Heating, ventilation and air conditioning systems - design and dimensions.
Clo is used as a measure of clothes thermal insulation.
Human metabolism at low and high activity with different levels of clothing.
Evaporation of water from a water surface - like a swimming pool or an open tank - depends on water temperature, air temperature, air humidity and air velocity above the water surface - online calculator.
Heat loss from electrical equipment like switch-gear, transformers and variable frequency drives.
Heat gain from persons in air conditioned spaces - in btu/hr.
Recommended indoor comfort temperatures vs. outdoor temperatures.
Recommended indoor temperature and humidity for common industrial products and production processes.
