Indoor Comfort Temperatures vs. Outdoor Temperatures
Recommended indoor comfort temperature versus outdoor dry-bulb temperatures are indicated below.
Outside Dry-Bulb Temperature
(oF)
Inside Temperature (oF)
Dry-BulbWet-BulbDew PointEffective Temperature
100 82.5 69.0 62.3 76.0
90 79.5 66.5 59.5 73.6
80 76.7 64.0 56.6 71.3
70 74.0 62.0 54.5 69.0
Example - Recommended Indoor Temperature
With an outside dry bulb temperature of 30 oC, the diagram above indicates the the recommended inside dry bulb temperature should be approximately 26 oC and the recommended inside wet bulb temperature should be approximately 17 oC
From the Mollier diagram this corresponds to relative humidity approximately 40% with humidity ratio - x - 0.0085 kgh2o/kgdry_air.
Air Conditioning
Air Psychrometrics
Clo - Clothing and Thermal Insulation
Clo is used as a measure of clothes thermal insulation.
Discomfort Index
Comfort vs. dry bulb, wet bulb and dew point temperature.
Dry Bulb, Wet Bulb and Dew Point Temperatures
Dry Bulb, Wet Bulb and Dew Point temperatures can be used to determine the state of humid air.
Indoor Design Temperatures
Recommended indoor temperatures in summer or winter.
Indoor Relative Humidity vs. Outdoor Relative Humidity and Temperature
Recommended indoor relative humidity vs. outdoor relative humidity and temperature.
Indoor Temperature and Humidity Loads
Calculate sensible and latent heat from persons, lights, electric equipment, machines, evaporation from water surfaces, polluting fluids and miscellaneous loads.
Moist Air - Psychrometric Terms
Dry and wet bulb temperature, specific volume, relative humidity,  enthalpy and more.
Wet Bulb Globe Temperature (WBGT)
The Wet Bulb Globe Temperature can be used to measure the general Heat-Stress index.
