temperature
Heating systems - capacity and design of boilers, pipelines, heat exchangers, expansion systems and more.
Clo is used as a measure of clothes thermal insulation.
Temperature points that can be used as a reference for calibration
The resultant or globe temperature.
Recommended indoor comfort temperatures vs. outdoor temperatures.
Recommended indoor design conditions summer or winter.
Recommended indoor temperature and humidity for common industrial products and production processes.
Pt100 electrical resistance temperature sensor - ranging -220 to 750 degrees Celsius.
Thermal resistive sensor - a basic introduction.
