Pt100 - Platinum Resistance Thermometer
The PT100 has a resistance of 100 ohms at 0 °C and 138.5 ohms at 100 °C.
Pt100 - Platinum Resistance Thermometer - Electrical Resistance
Temperature
(oC)
(Ω)
-220 10.41
-200 18.53
-180 27.05
-160 35.48
-140 43.80
-120 52.04
-100 60.20
-80 68.28
-60 76.28
-40 84.21
-30 88.17
-20 92.13
-10 96.07
0 100.00
10 103.90
20 107.79
30 111.67
40 115.54
50 119.40
60 123.24
80 130.89
100 138.50
120 146.06
140 153.57
160 161.04
180 168.47
200 175.84
220 183.17
240 190.46
260 197.70
280 204.88
300 212.03
320 219.13
340 226.18
360 233.19
380 240.15
400 247.06
420 253.93
440 260.75
460 267.52
480 274.25
500 280.93
520 287.57
540 294.16
560 300.70
580 307.20
600 313.65
620 320.05
640 326.41
660 332.72
700 345.21
750 360.55
Note! - there are also PT1000 sensors with resistance 1000 ohms at 0 °C.
The linearization equation for the Pt100 thermometer is
Rt = R0 (1 + A t + B t2 + C (t - 100) t3)              (1)
Rt = resistance at temperature t  (ohm)
R0 = resistance at temperature 0oC (ohm)
t = temperature (oC)
A = 3.9083 10–3
B = –5.775 10–7
C = –4.183 10–12 (for temperatures below 0oC)
C = 0 (for temperatures above 0 °C)
Temperature Measurement
Dry Bulb, Wet Bulb and Dew Point Temperatures
Dry Bulb, Wet Bulb and Dew Point temperatures can be used to determine the state of humid air.
Fixed Temperature Points
Temperature points that can be used as a reference for calibration
Indoor Design Temperatures
Recommended indoor temperatures in summer or winter.
Outdoor Temperatures and Relative Humidity - US Winter and Summer Conditions
Outdoor summer and winter design temperatures and relative humidity for US states and cities.
RTD Resistance Temperature Sensor
Thermal resistive sensor - a basic introduction.
Temperature
Temperature Sensors - Comparing Types
Comparing advantages and disadvantages of thermocouples, RTDs and thermistors temperature sensors.
Thermocouple Temperature Measurements
An introduction to the frequently used temperature transducers - the thermocouple.
Thermocouples
Thermocouples - types, principles and temperature ranges.
