-350oF
+3200oF
Instrumentation and process control systems - design and documentation.
Temperature points that can be used as a reference for calibration
Pt100 electrical resistance temperature sensor - ranging -220 to 750 degrees Celsius.
Thermal resistive sensor - a basic introduction.
Thermocouples - types, principles and temperature ranges.
