Fixed Temperature Points
Temperature defining points of the International Practical Temperature Scale of 1990 (ITS90):
SubstanceTemperature
(K)
Triple point of hydrogen 13.8033
Triple point of neon 24.5561
Triple point of oxygen 54.3584
Triple point of argon 83.8058
Triple point of mercury 234.3156
Triple point of water 273.16
Melting point of gallium 302.9146
Freezing point of indium 429.7485
Freezing point of tin 505.078
Freezing point of zinc 692.677
Freezing point of aluminum 933.573
Freezing point of silver 1234.93
Freezing point of gold 1337.33
Freezing point of copper 1357.77
Temperature Measurement
Dry Bulb, Wet Bulb and Dew Point Temperatures
Dry Bulb, Wet Bulb and Dew Point temperatures can be used to determine the state of humid air.
Indoor Design Temperatures
Recommended indoor temperatures in summer or winter.
Outdoor Temperatures and Relative Humidity - US Winter and Summer Conditions
Outdoor summer and winter design temperatures and relative humidity for US states and cities.
Pt100 - Platinum Resistance Thermometer
Pt100 electrical resistance temperature sensor - ranging -220 to 750 degrees Celsius.
RTD Resistance Temperature Sensor
Thermal resistive sensor - a basic introduction.
Selecting Temperature Sensors
RTD vs. thermocouples temperature sensors.
Temperature
Temperature Sensors - Comparing Types
Comparing advantages and disadvantages of thermocouples, RTDs and thermistors temperature sensors.
Thermocouple Temperature Measurements
An introduction to the frequently used temperature transducers - the thermocouple.
Thermocouples
Thermocouples - types, principles and temperature ranges.
Trusses
Common types of trusses.
