Thermocouple Temperature Measurements
An introduction to the frequently used temperature transducers - the thermocouple.
https://s3.amazonaws.com/files.technologyreview.com/p/pub/legacy/temperature_measurements_with_thermocouples.pdf
Fixed Temperature Points
Temperature points that can be used as a reference for calibration
Pt100 - Platinum Resistance Thermometer
Pt100 electrical resistance temperature sensor - ranging -220 to 750 degrees Celsius.
