Trusses
Somme common types of trusses are
- Warren
- King post
- Bridge
- English Howe
- Howe
- K truss
- Pratt
- Fink
- Baltimore
- Parker
- Bowstring
Warren Truss
King Post Truss
English Howe Truss
Howe Truss
K Truss
Pratt Truss
Fink Truss
Baltimore Truss
Parker Truss
Bowstring Truss
• Beams and Columns
• Mechanics
• Statics
American Standard Steel C Channels
American Wide Flange Beams
Beams - Fixed at Both Ends - Continuous and Point Loads
Beams - Supported at Both Ends - Continuous and Point Loads
Cantilever Beams - Moments and Deflections
Drawbridge - Force and Moment vs. Elevation
Calculate the acting forces and moments when elevating drawbridges or beams.
Factors of Safety - FOS
Factors of Safety - FOS - are important in engineering designs.
Fixed Temperature Points
Temperature points that can be used as a reference for calibration
Horizontal Roof Rafters - Maximum Spans
Douglas Fir in horizontal roof rafters and maximum spans.
Maximum Floor Joist Span
No. 1 and No. 2 Grade of Douglas fir and maximum span floor joists - imperial units
Modulus of Rigidity
Softwood and Hardwood - Structural Strength Classes
Strength classes, bending stress and mean density of hardwood and softwood
Structural Lumber - Properties
W Steel Beams - Allowable Uniform Loads
Allowable uniform loads.
W-Beams - American Wide Flange Beams
Wood Headers - Max. Supported Weight
Young's Modulus, Tensile Strength and Yield Strength Values for some Materials
Young's Modulus (or Tensile Modulus alt. Modulus of Elasticity) and Ultimate Tensile Strength and Yield Strength for materials like steel, glass, wood and many more.
