Indoor Conditions - Summer or Winter
For full table with Winter Conditions - rotate the screen!
Application | Summer | Winter | |||||
Extra | Commercial | With Humidification | Without Humidification | ||||
Dry Bulb Temperature | Relative Humidity | Dry Bulb Temperature | Relative Humidity | Dry Bulb Temperature | Relative Humidity | Dry Bulb Temperature | |
(oF) | (%) | (oF) | (%) | (oF) | (%) | (oF) | |
General Comfort Apartment, House, Hotel, Office, Hospital, School .. |
74 - 76 | 50 - 45 | 77 - 79 | 50 - 54 | 74 - 76 | 35 - 30 | 75 - 77 |
Retail Shops for shorter terms occupancy Bank, barber shop, beauty shop, department store, supermarket .. |
76 - 78 | 50 - 45 | 78 - 80 | 50 - 45 | 72 - 74 | 35 - 30 | 73 - 75 |
High latent load and low sensible load applications Auditoriums, churches, bars, restaurants, kitchens |
76 - 78 | 55 - 50 | 78 - 80 | 65 - 50 | 72 - 74 | 40 - 35 | 74 - 76 |
Factories Work shops, assembly areas, machining rooms .. |
77 - 80 | 55 - 45 | 80 - 85 | 60 - 50 | 68 - 72 | 35 - 30 | 70 - 74 |
• Air Conditioning Systems
Clo - Clothing and Thermal Insulation
Clo is used as a measure of clothes thermal insulation.
Dry Bulb, Wet Bulb and Dew Point Temperatures
Dry Bulb, Wet Bulb and Dew Point temperatures can be used to determine the state of humid air.
Fruits and Vegetables - Optimal Storage Conditions
Optimal temperature and humidity conditions for common fruits and vegetables.
Indoor Design Temperatures
Recommended indoor temperatures in summer or winter.
Industrial Product and Production Processes - Climate Conditions
Recommended indoor temperature and humidity for common industrial products and production processes.
Outdoor Temperatures and Relative Humidity - U.S. Winter and Summer Conditions
Outdoor summer and winter design temperatures and relative humidity for U.S. states and cities.
Wet Bulb Globe Temperature (WBGT)
The Wet Bulb Globe Temperature can be used to measure the general Heat-Stress index.
