Discomfort Index
The Discomfort Index can be expressed as
DI = 0.4 (td + tw) + 15                           (1)
or alternatively
DI = 0.55 td + 0.2 tdp + 17.5                         (1b)
DI = Discomfort Index
td = dry bulb temperature (oF)
tw = wet bulb temperature (oF)
tdp = dew point temperature (oF)
The higher the value - the higher the value of discomfort.
Physiology
Clo - Clothing and Thermal Insulation
Clo is used as a measure of clothes thermal insulation.
Dry Bulb, Wet Bulb and Dew Point Temperatures
Dry Bulb, Wet Bulb and Dew Point temperatures can be used to determine the state of humid air.
Heat Discomfort Zones
Maximum work load vs. temperature and relative humidity.
Heat Index
Equivalent heat index vs. air temperature and relative humidity - in degrees Fahrenheit and Celsius.
Human Effort Levels - Energy and Heart Rates
Human work effort levels vs. energy expenditure and associated heart rates.
Indoor Comfort Temperatures vs. Outdoor Temperatures
Recommended indoor comfort temperatures vs. outdoor temperatures.
Metabolic Heat Gain from Persons
Human metabolic heat gain in air conditioned rooms.
Moist Air - Psychrometric Terms
Dry and wet bulb temperature, specific volume, relative humidity,  enthalpy and more.
Outdoor Makeup Air
Acceptable indoor air quality and required make up air.
Predicted Mean Vote Index (PMV)
PMV index predicts mean comfort response of a larger group of people.
