Moist Air - Vapor Pressure
Vapor pressure in moist air vs. wet and dry bulb temperatures are indicated in the charts below:
Vapor Pressure - kPa
Vapor Pressure - inches Mercury
Air Psychrometrics
Liquids - Vapor Pressures
Vapor and saturation pressure for some common liquids.
Moist Air - Relative Humidity
Relative humidity in moist air is the ratio of partial vapor pressure to air pressure.
Moist Air - Water Vapor and Saturation Pressure
Saturation pressure of water vapor in moist air vs. temperature.
Removing Heat with Air
Calculating heat removed with air by measuring the wet bulb temperature.
Water Vapor Saturation Pressure: Data, Tables & Calculator
