Moist Air - Psychrometric Table for Pressure 29.92 inHg
Dry Bulb Temperature
Saturated Water Vapour
Heat Dry Air
Air Saturated with Water VaporWet Bulb Temperature
Pressure
Weight
Volume
Weight, GrainsHeat Content per lb. Dry Air and Vapor to Saturate It
(oF)(inches of Mercury)(Grains per Cu. Ft. of Vapor)(Grains per Pound of Dry Air)(Btu per lb above 0 oF)(Cu. Ft of 1 lb dry Air and Vapor to saturate it)(Dry Air in 1 Cu. Ft. of Mixture)(Air and Vapor in 1 Cu. Ft. of Mixture)(Heat of Vapor Above 31 oF)(Total Enthaply Btu)(oF)
-40 0.0039 0.054 0.569 -9.60 10.58 661.4 661.5 0.085 -9.515 -40
-30 0.0069 0.093 1.004 -7.20 10.84 646.1 646.2 0.150 -7.050 -30
-20 0.0126 0.165 1.834 -4.80 11.09 631.3 631.5 0.276 -4.524 -20
-10 0.0222 0.285 3.233 -2.40 11.34 617.2 617.5 0.488 -1.920 -10
0 0.0383 0.481 5.58 0.00 11.60 603.2 603.7 0.846 0.846 0
10 0.0631 0.775 9.19 2.40 11.86 590.4 591.1 1.40 3.799 10
20 0.103 1.239 15.04 4.80 12.14 576.8 578.0 2.30 7.099 20
30 0.164 1.933 23.99 7.20 12.41 563.9 565.9 3.68 10.88 30
40 0.2478 2.864 36.36 9.60 12.69 551.4 554.3 5.61 15.21 40
50 0.3626 4.110 53.41 12.00 13.00 538.7 542.8 8.27 20.27 50
60 0.5218 5.801 77.27 14.40 13.32 524.5 531.3 12.01 26.41 60
70 0.7392 8.065 110.28 16.80 13.67 511.9 520.0 17.21 34.01 70
80 1.0321 11.06 155.52 19.20 14.07 497.7 508.7 24.37 43.57 80
90 1.4215 14.96 217.13 21.60 14.52 482.2 497.2 34.15 55.75 90
100 1.9325 19.98 300.60 24.00 15.05 465.2 485.2 47.46 71.46 100
110 2.5955 26.38 413.50 26.40 15.68 446.5 472.9 65.54 91.94 110
120 3.4458 34.44 566.67 28.80 16.46 425.4 456.8 90.16 118.96 120
130 4.5251 44.49 775.80 31.20 17.44 401.4 445.9 123.90 155.10 130
140 5.8812 56.91 1065.1 33.60 18.71 374.1 431.0 170.72 204.32 140
150 7.569 72.11 1474.3 36.00 20.44 342.5 414.6 237.17 273.17 150
160 9.652 90.57 2073.2 38.40 22.89 305.8 396.4 334.73 373.13 160
170 12.199 112.79 2996.9 40.80 26.57 263.5 376.2 485.59 526.39 170
180 15.291 139.36 4550.4 43.20 32.65 214.4 353.7 739.81 783.01 180
190 19.014 170.90 7589.5 45.60 44.41 157.6 328.5 1237.93 1283.53 190
200 23.467 208.09 15828.9 48.00 76.07 92.0 300.1 2591.88 2638.88 200
Air Psychrometrics
Air - Psychrometric Chart for Standard Atmospheric Conditions - Imperial Units
Psychrometric chart to analyze air properties, including temperature, humidity, enthalpy, and dew point at barometric pressure 29.921 inches of Mercury and temperature ranging 20oF to 120oF.
Dry Bulb, Wet Bulb and Dew Point Temperatures
Dry Bulb, Wet Bulb and Dew Point temperatures can be used to determine the state of humid air.
Heat Recovery Efficiency
Mixing of Humid Air
Moist Air - Cooling and Dehumidifying
Cooling and dehumidifying processes of moist and humid air - sensible and latent cooling.
Moist Air - Enthalpy
Moist Air - Properties
Psychrometric table with humid air properties like saturation pressure, specific volume, enthalpy and entropy.
Moist Air - Psychrometric Chart for Normal Temperatures at 7500 Feet Altitude
Psychrometric chart in I-P Units at 7500 feet and barometric pressure 22.653 inHG.
Moist Air - Psychrometric Terms
Dry and wet bulb temperature, specific volume, relative humidity,  enthalpy and more.
Moist Air - Relative Humidity
Relative humidity in moist air is the ratio of partial vapor pressure to air pressure.
Moist Air - Specific Volume
Specific volume of moist air is defined as the total volume of humid air per mass unit of dry air
Moist Air - Water Vapor and Saturation Pressure
Saturation pressure of water vapor in moist air vs. temperature.
