Moist Air - Psychrometric Chart for Normal Temperatures at 7500 Feet Altitude
A psychrometric chart at 7500 feet and 22.653 inches of Mercury. Enthalpy in btu/lb dry air.
https://www.ashrae.org/File%20Library/Technical%20Resources/Bookstore/UP3/IP-9.pdf
Air Psychrometrics
Moist Air - Psychrometric Chart for High Temperatures at Sea Level
Psychrometric Chart in I-P Units for high temperatures at sea level and with a barometric pressure of 29.921 inHG.
Moist Air - Psychrometric Chart for Low Temperatures at Sea Level
Psychrometric chart in I-P Units for low temperature at sea level and barometric pressure 29.921 inHG.
Moist Air - Psychrometric Chart for Normal Temperatures at 5000 Feet Altitude
Psychrometric chart in I-P Units at 5000 feet and barometric pressure 24.896 inHG.
Moist Air - Psychrometric Table for Pressure 29.92 inHg
Dry and wet bulb temperatures, saturation pressure, water vapor weight, specific volume, heat and more.
