Moist Air - Psychrometric Chart for Normal Temperatures at 5000 Feet Altitude
A psychrometric chart at 5000 feet and 24.896 inches of Mercury. Enthalpy in btu/lb dry air.
https://www.teachengineering.org/content/cub_/activities/cub_housing/cub_housing_lesson01_activity2_psychrometricchart.pdf
Air Psychrometrics
Moist Air - Psychrometric Chart for High Temperatures at Sea Level
Psychrometric Chart in I-P Units for high temperatures at sea level and with a barometric pressure of 29.921 inHG.
Moist Air - Psychrometric Chart for Low Temperatures at Sea Level
Psychrometric chart in I-P Units for low temperature at sea level and barometric pressure 29.921 inHG.
Moist Air - Psychrometric Chart for Normal Temperatures at 7500 Feet Altitude
Psychrometric chart in I-P Units at 7500 feet and barometric pressure 22.653 inHG.
