Soil - Water Content
Water or moisture content in soil can be expressed as
w = 100 Mw / Ms                     (1)
w = moisture content (%)
Mw = mass of water in soil (kg, lb)
Ms = dry mass of soil (kg, lb)
Water content can be tested according ASTM D 2216-92 by determining the mass of the wet soil specimen and then drying the soil in an oven 12 - 16 hours at a temperature of 110 oC. Values can vary from essentially 0% (near surface rubble, gravel or clean sand) up to 1200% (organic soil like fibrous peat).
Environment
Excavation Slopes
Calculating excavation slope.
Geological Time
Geological periods and time scale.
Moisture Content Calculation
Calculate the moisture content in products like wood on wet and dry basis.
Soil - Earth Weight and Composition
Typical weight and composition of soil.
Trench Excavation
Estimate trench excavation - online calculator.
