Pipe and Tubing Formulas
Online Pipe Formula Calculator
The calculator is based on the piping formulas and equations below.
Moment of Inertia
Moment of inertia can be expressed as
I = π (do4 - di4) / 64
≈ 0.0491 (do4 - di4) (1)
I = moment of inertia (in4)
do = outside diameter (in)
di = inside diameter (in)
Section Modulus
Section modulus can be expressed as
S = 0.0982 (do4 - di4) / do (2)
S = section modulus (in3)
Section modulus is a geometric property for a given cross-section used in the design of beams or flexural members.
Transverse Metal Area
Transverse metal area can be expressed as
Am = π (do2 - di2) / 4 (3)
Am = transverse metal area (in2)
External Pipe Surface
External pipe or tube surface per ft of length can be expressed as
Ao = π do / 12 (4)
Ao = external pipe surface area (ft2 per ft pipe)
Internal Pipe Surface
Internal pipe or tube surface per ft of length can be expressed as
Ai = π di / 12 (5)
Ai = internal pipe surface area (ft2 per ft pipe)
Transverse Internal Area
Transverse internal area can be expressed as
Aa = 0.7854 di2 (6)
Aa = transverse internal area (in2)
Circumference External
External circumference can be expressed as
Ce = π do (7)
Ce = external circumference (in)
Circumference Internal
Internal circumference can be expressed as
Ci = π di (8)
Ci = internal circumference (in)
Estimating Pipe Circumference and Section Area
Nominal Pipe Size (in) | Circumference (in) | Section Area (sq.in.) |
1/4 | 0.785 | 0.049 |
3/8 | 1.178 | 0.110 |
1/2 | 1.571 | 0.196 |
3/4 | 2.356 | 0.442 |
1 | 3.142 | 0.785 |
1 1/4 | 3.927 | 1.227 |
1 1/2 | 4.712 | 1.767 |
2 | 6.283 | 3.142 |
2 1/2 | 7.854 | 4.909 |
3 | 9.425 | 7.069 |
3 1/2 | 11.00 | 9.621 |
4 | 12.57 | 12.57 |
5 | 15.71 | 19.64 |
6 | 18.85 | 28.27 |
8 | 25.13 | 50.27 |
10 | 31.42 | 78.54 |
12 | 37.70 | 113.1 |
15 | 47.12 | 176.7 |
ANSI Steel Pipe Schedule 40 Chart: Dimensions, Weights & Specifications
Area Moment of Inertia Converter
Convert between Area Moment of Inertia units.
Area Moment of Inertia with Definitions, Formulas & Calculator
Explore the area moment of inertia (second moment of area) with detailed formulas, calculation tools, and reference tables for common shapes. Essential for structural and mechanical engineering applications.
Area Units Converter
Convert between units of area.
Mass Moment of Inertia
The Mass Moment of Inertia vs. mass of object, it's shape and relative point of rotation - the Radius of Gyration.
Piping Equations
Calculate cross-sectional areas, weight of empty pipes, weight of pipes filled with water, inside and outside surface areas.
Radius of Gyration in Structural Engineering
Radius of gyration describes the distribution of cross sectional area in columns around their centroidal axis.
Section Modulus - Unit Converter
Convert between Elastic Section Modulus units.
