Area Moment of Inertia Converter
Area Moment of Inertia or Moment of Inertia of an Area - also known as Second Moment of Area - I, is a property of shape that is used to predict deflection, bending and stress in beams.
The general equation for Moment of Inertia for bending around an axis can be expressed as
Iaxis = ∫ y2 dA                          (1)
Iaxis = Area Moment of Inertia related to an axis (m4, mm4, in4, ft4)
y = the perpendicular distance from axis to the element dA (m, mm, in, ft)
dA = an elemental area (m2, mm2, in2, ft2)
Convert from
Multiply with
Convert to
m4cm4mm4in4ft4
m4 1 108 1012 2.4×106 116.3
cm4 10-8 1 104 2.4×10-2 1.2×10-6
mm4 10-12 10-4 1 2.4×10-6 1.2×10-10
in4 4.16×10-7 41.6 4.16×105 1 4.8225×10-5
ft4 8.6×10-3 8.6×105 8.6×109 207346 1
Example - Convert between Area of Inertia Units
To convert from 160.6 cm4 to in4 multiply with 2.4×10-2 as
(160.6 cm4) 2.4×10-2 = 3.9 in4
Moment of Inertia - Unit Converter Chart
Download and print Moment of Inertia - Unit Converting Chart
Moment of Inertia - Unit Converting Chart Example
100 cm4 (1.00×102 cm4) can be converted to 10000000 mm4 (1.00×107 mm4) or 24 in4 (2.4×101 in4) as indicated in the chart below:
Beams and Columns
Mechanics
Statics
American Wide Flange Steel Beams: Dimensions and Properties (ASTM A6 in Metric)
Area Moment of Inertia - Typical Cross Sections II
Area Moment of Inertia, Moment of Inertia for an Area or Second Moment of Area for typical cross section profiles.
Area Moment of Inertia with Definitions, Formulas & Calculator
Explore the area moment of inertia (second moment of area) with detailed formulas, calculation tools, and reference tables for common shapes. Essential for structural and mechanical engineering applications.
Beams Fixed at Both Ends with Continuous and Point Loads: Load & Deflection Formulas
Mass Moment of Inertia
The Mass Moment of Inertia vs. mass of object, it's shape and relative point of rotation - the Radius of Gyration.
Pipe and Tubing Formulas
Pipe and Tube Equations - moment of inertia, section modulus, traverse metal area, external pipe surface and traverse internal area - imperial units
Radius of Gyration in Structural Engineering
Radius of gyration describes the distribution of cross sectional area in columns around their centroidal axis.
Section Modulus - Unit Converter
Convert between Elastic Section Modulus units.
Structural Lumber - Section Sizes
Basic size, area, moments of inertia and section modulus for timber - metric units.
Unit Factor Method
