ASTM F2389 Pressure-rated Polypropylene (PP) - Dimensions
Dimensions of Polypropylene pipes according ASTM F2389 Standard Specification for Pressure-rated Polypropylene (PP) Piping Systems SDR 7.4, 9 and 11:
Nominal Pipe Size
(inches)
SDROutside Diameter
(inches)
Wall Thichness
(inches)
1/2 7.4 0.787 0.110
3/4 7.4 0.984 0.138
1 9 1.260 0.142
1 11 1.260 0.114
1 1/4 9 1.575 0.177
1 1/4 11 1.575 0.146
1 1/2 9 1.969 0.220
1 1/2 11 1.969 0.181
2 9 2.480 0.280
2 11 2.480 0.228
2 1/2 9 2.953 0.331
2 1/2 11 2.953 0.268
3 9 3.543 0.398
3 11 3.543 0.323
4 9 4.921 0.551
4 11 4.921 0.449
6 9 6.300 0.705
6 11 6.300 0.575
8 9 7.872 0.882
8 11 7.872 0.716
10 9 9.842 1.098
10 11 9.842 0.894
12 9 12.401 1.386
12 11 12.401 1.126
Dimensions of Pipes and Tubes
ASTM D2241 - Poly(Vinyl Chloride) (PVC) Pressure-Rated Pipe (SDR Series) - Dimensions
Dimensions of PVC pipe SDR series.
EN 1451 - Polypropylene (PP) Plastics Piping Systems for Soil and Waste Discharge - Dimensions
Plastic piping systems for soil and waste discharge (low and high temperature) within the building structure.
Linear Thermal Expansion Coefficients of Materials
Linear thermal expansion coefficients of common materials, including metals, plastics, and composites.
Plastic Pipes - Friction Head Loss vs. Water Flow
PP - PolyPropylene Pipes - Support Spacing
Maximum distance between PolyPropylene pipes supports.
PP Polypropylene - Chemical Resistance
Chemical resistance of Polypropylene - PP - to acids, bases, organic substances and solvents.
Thermoplastic Pipes - Support Distance vs. Temperature
Maximum space between supports for PVC, CPVC, PVDF and PP pipes vs. temperature.
