Carbon and Stainless Steel Flanges - ASME/ANSI Class 2500
ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings - Class 2500 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts for Weld neck, Threaded, Slip-on, Lap joint, Socket weld and Blind flanges.
Carbon and stainless steel qualities according ASME B16.5 Table 1A.
Pipe Size (inches) | Flange Outside Diameter (inches) | Pipe Outside Diameter (inches) | Number of Bolt Holes | Bolt Hole Diameter (inches) 1) | Bolt Circle (inches) |
1/2 | 5-1/4 | 0.84 | 4 | 7/8 | 3-1/2 |
3/4 | 5-1/2 | 1.05 | 4 | 7/8 | 3-3/4 |
1 | 6-1/4 | 1.32 | 4 | 1 | 4-1/4 |
1-1/4 | 7-1/4 | 1.66 | 4 | 1-1/8 | 5-1/8 |
1-1/2 | 8 | 1.90 | 4 | 1-1/4 | 5-3/4 |
2 | 9-1/4 | 2.38 | 8 | 1-1/8 | 6-3/4 |
2-1/2 | 10-1/2 | 2.88 | 8 | 1-1/4 | 7-3/4 |
3 | 12 | 3.50 | 8 | 1-3/8 | 9 |
4 | 14 | 4.50 | 8 | 1-5/8 | 10-3/4 |
5 | 16-1/2 | 5.56 | 8 | 1-7/8 | 12-3/4 |
6 | 19 | 6.63 | 8 | 2-1/8 | 14-1/2 |
8 | 21-3/4 | 8.63 | 12 | 2-1/8 | 17-1/4 |
10 | 26-1/2 | 10.75 | 12 | 2-5/8 | 21-1/4 |
12 | 30 | 12.75 | 12 | 2-7/8 | 24-3/8 |
1) Recommended bolts are 1/8 smaller than the nominal bolt hole diameters shown.
- 1 inch = 25.4 mm
• Piping Systems
ASTM Flanges - Hydrostatic Test Pressures
Flanged fittings and required hydrostatic test pressure.
Butt-Welding Fittings - Dimensions
Butt-Welding Fittings - B16.9 - dimensions.
Carbon and Stainless Steel Flanges - ASME/ANSI Class 1500
ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings - Class 1500 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Carbon and Stainless Steel Flanges - ASME/ANSI Class 300
ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings - Class 300 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Carbon and Stainless Steel Flanges - ASME/ANSI Class 400
ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings - Class 400 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Carbon and Stainless Steel Flanges - ASME/ANSI Class 600
ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings - Class 600 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Carbon and Stainless Steel Flanges - ASME/ANSI Class 900
ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings - Class 900 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Stainless Steel Weld Fittings - ANSI/ASME B36.19
Dimensions of stainless steel weld fittings according ANSI/ASME B36.19.
