Levers
A lever is a mechanism that can be used to exert a large force over a small distance at one end of the lever by exerting a small force over a greater distance at the other end.
The moment action on both sides of the lever is equal and can be expressed as
Fe de = Fl dl                             (1)
Fe = effort force (N, lb)
Fl = load force (N, lb) (note that weight is a force)
dl = distance from load force to fulcrum (m, ft)
de = distance from effort force to fulcrum (m, ft)
The effort force can be calculated by modifying (1) to
Fe = Fl dl / de
    = m ag dl / de                        (1b)
m = mass (kg, slugs)
ag = acceleration of gravity (9.81 m/s2, 32.17 ft/s2)
Lever Calculator
This calculator can used to calculate lever effort force. It can be used for both metric and imperial units as long as the use of units are consistent.
Example - Improvised Car Lift
An improvised car lift can be made with a piece of lumber as illustrated in the figure above. With distance load to fulcrum 0.2 m, distance effort force to fulcrum 2 m and a load on the lever - half the weight of the car 2000 kg - the effort force can be calculated
Fe = (0.5 2000 kg) (9.81 m/s2) (0.2 m) / (2 m)
    = 981 N
    ≈ 100 kg
Orders of Levers
First-order levers
  • the fulcrum is positioned between the effort and the load
  • the effort is smaller than the load
  • the effort moves further than the load
  • the lever can be considered as a force magnifier
Second-order Levers
  • the effort and the load are positioned on the same side of the fulcrum but applied in opposite directions
  • the load lies between the effort and the fulcrum
Third-order Levers
  • the effort lies between the load and the fulcrum
  • the effort is greater than the load
  • the load moves further than the effort
  • the lever can be considered as a distance magnifier
Example - First-Class (Order) Lever - A force (weight) of 1 pound is exerted at the end of a lever at distance 1 ft from the fulcrum
The effort force at a distance of 2 ft from the fulcrum can be calculated as
Fe = (1 lb) (1 ft) / (2 ft)
    = 0.5 (lb)
The formula (1) can be modified to express required load if you know the effort, or required distance from fulcrum if load and effort forces are known and so on.
The level above where the fulcrum located between the load and effort force is often characterized as a first-class level mechanism.
A level where the load and effort force are located on the same side of the fulcrum is often characterized as a second-class level mechanism.
Example - Second-Class (Order) Lever
A force (weight) of 1 pound is exerted at a distance of 1 ft from the fulcrum.
Fe = (1 lb) (1 (ft) / (2 ft)
    = 0.5 (lb)
Example - Lever calculation with SI-units - weight of 1 kg mass acting 1 m from the fulcrum
The effort force at a distance of 2 m from the fulcrum can be calculated as
Fe = (1 kg) (9.81 m/s2) (1 m) / (2 m)
    = 4.9 N
A lever mechanism where the input effort is higher than than the output load is often characterized as a third-class lever mechanism.
Example - Third-Class (Order) Lever
A force (weight) of 1 pound is exerted at a distance of 2 ft from the fulcrum.
The effort force at a distance of 1 ft from the fulcrum can be calculated as
Fe = Fl dl / de
    = (1 lb) (2 ft) / (1 ft)
    = 2 (lb)
One or more forces acting on a lever
A lever with two acting load forces and one effort force is indicated in the sketch below:
The generic equation for one effort force with one or more acting load forces can be expressed as
Fe = (FlA dlA +  FlB dlB +.. + FlN dlN ) / de                                                (2)
This equation is modified for three acting loads below.
Example - A Lever with three acting loads and one effort force
A weight A of 1 pound is exerted at a distance of 1 ft from the fulcrum. A weight B of 2 pound is exerted at a distance of 2 ft from the fulcrum, and a weight C of 3 pound is exerted at a distance of 3 ft from the fulcrum.
Fe = (FlA dlA +  FlB  dlB +FlC dlC ) / de
    = ((1 lb) (1 ft) + (2 lb) (2 ft) + (3 lb) (3 ft)) / (2 ft)
    = 7 (lb)
Mechanics
Statics
Cantilever Beams - Moments and Deflections
An introduction to density, specific weight and specific gravity.
Elevators - Force and Power
Required force and power to lift an elevator.
Force
Force Ratio
The force ratio is the load force versus the effort force.
Improvised Torque Wrench
Mass vs. Weight
Screw Jack - Effort Force vs. Load
Screw jacks and effort forces.
Threaded Rods - Proof Loads - Metric Units
Proof load capacities of metric threaded steel rods.
Toggle Joint
A toggle joint mechanism can be used to multiply force.
