Velocity Units - Online Converter
Online Velocity Units Calculator
The calculator below can be used to convert between common velocity and speed units:
Velocity Units Converting Table
The table below can be used to convert between common velocity and speed units:
| Convert from | Multiply by | ||||||
| Convert to | |||||||
| m/s | km/h | ft/min | ft/s | yards/min | mph | knots | |
| m/s | 1 | 3.6 | 196.9 | 3.28 | 65.6 | 2.24 | 1.94 |
| km/h | 0.278 | 1 | 54.68 | 0.91 | 18.23 | 0.62 | 0.54 |
| ft/min | 5.08×10-3 | 1.83×10-2 | 1 | 1.67×10-2 | 0.33 | 1.14×10-2 | 9.87×10-3 |
| ft/s | 0.305 | 1.097 | 60 | 1 | 20 | 0.682 | 0.592 |
| yards/min | 1.52×10-2 | 5.49×10-2 | 3 | 0.05 | 1 | 3.41×10-2 | 2.96×10-2 |
| mph | 0.45 | 1.609 | 88 | 1.47 | 29.33 | 1 | 0.869 |
| knots | 0.51 | 1.85 | 101.3 | 1.69 | 33.76 | 1.15 | 1 |
Some other common Velocity Units
- 1 metre per second = 6000 centimetre per minute
- 1 metre per second = 100 centimetre per second
- 1 metre per second = 11811 feet per hour
- 1 metre per second = 2362.2 inches per minute
- 1 metre per second = 39.37 inches per second
- 1 metre per second = 1.942615 knots
- 1 metre per second = 3600 metre per hour
- 1 metre per second = 60 metre per minute
- 1 metre per second = 0.0373 miles per minute
- 1 metre per second = 0.00062 miles per second
- 1 metre per second = 3937 yards per hour
mph to km/h Converter
Download and print mph to km/h Converter!
m/s to km/h Converter
• Basics
Acceleration Units Converter
Converting between units of acceleration.
Acceleration vs. Velocity Equations
Useful equations related to acceleration, average velocity, final velocity and distance traveled.
Average Velocity
Distance traveled vs. time used.
Common converting units for Acceleration, Area, Density, Energy, Energy per unit mass, Force, Heat flow rate, Heat flux, Heat generation per unit volume and many more.
Unit Factor Method
Velocity Units Converter
Convert between speed and velocity units like m/s, km/h, knots, mph and ft/s.
