12 Volt - Electric Automotive Wiring
Current loads and maximum wire lengths in 12V electric systems are indicated in the diagrams below.
print 12V Automotive Electric Wiring Chart
- 1 ft (foot) = 0.3048 m
Current load - amps - and maximum wire length is based on maximum 0.5 volt voltage drop over the length of the wire.
• Electrical
12 Volt - Maximum Wire Length vs. Current
Maximum length of copper wire with 2% voltage drop.
AWG Wire Gauge Chart & Table – American Wire Gauge (AWG) Standards
The AWG (American Wire Gauge) wire size chart with detailed specifications on wire diameter, resistance, and ampacity. Find conversions between AWG sizes and metric units for electrical and engineering applications.
Electric Wire - Resistance
Electric resistance in wire made of Copper, Aluminum, Brass, Constantan, Nichrome, Platinum, Silver or Tungsten.
Electrical Vehicle Charging - Power vs. Voltage and Amps
EV Charging - AC vs. DC, single phase vs. three phase and power vs. voltage and amps.
New vs. Old Car Costs: A Comprehensive Cost Comparison
Compare the total cost of owning a new car versus an old car, including purchase price, maintenance, fuel efficiency, insurance, and depreciation. Use our detailed breakdown to make an informed financial decision before buying the next vehicle.
Piston Engines - Compression Ratios
Cylinder volume and compression ratios in piston engines.
