Shackles - Safe Loads
Safe load shackles:
Size
(in)
Safe Load
(tons)
1/4 1/3
5/16 1/2
3/8 3/4
7/16 1
1/2 1 1/2
5/8 2
3/4 3
7/8 4
1 5 1/2
  • check with the manufacturer for exact data
  • 1 in = 25.4 mm
  • 1 ton = 2000 lbs = 907 kg
Download and print Shackle Safe Load Chart
Miscellaneous
Bollard Forces
Friction, load and effort forces acting in ropes turned around bollards.
Cable Loads
Force and tension in cables with uniform loads.
Factors of Safety - FOS
Factors of Safety - FOS - are important in engineering designs.
Force
Lifting Wheels
Loads and effort force with lifting wheels.
Nylon Ropes - Strengths
Nylon 3-strand and 8-strand rope - minimum breaking strength and safe load.
Pulleys
Pulleys, blocks and tackles.
Screw Jack - Effort Force vs. Load
Screw jacks and effort forces.
Threaded Rods - Loads in Imperial Units
Weight rating of threaded hanger rods.
Winches
Effort force to raise a load.
Wire Rope Slings
Wire Ropes - Strengths
6 strand x 19 wire (6x19) - minimum breaking strength, safe loads and weight.
