- α -
(degrees)
The capacity of a single rope that follows a vertical line is 100% since the reduction factor is 1.
If the weight of a body is W - the load in the wire is
F = W (2)
F = force in rope (N, lbf)
W = m g = weight of body (N, lbf)
m = mass of body (kg, slugs)
g = acceleration of gravity (9.81 m/s2, 32.17 ft/s2)
For a body with mass 100 kg the load in the rope can be calculated
F = (100 kg) (9.81 m/s2)
= 981 N
= 9.8 kN
The capacity of two wires that follows the vertical line is 100% since the reduction factor is 1.
If the weight of a body is W - the load in each wire is
F = W / 2 (3)
For a body with weight 1000 N the load in each rope can be calculated as
F = (1000 N) / 2
= 500 N
= 0.5 kN
The capacity of two wires with angle 30o to the vertical line is 86.6% since the reduction factor is 0.866.
F = (W / 2) / cos(30o)
= (W / 2) / f
= (W / 2) / 0.866
= 0.577 W (4)
For a body with weight 1000 N the loads in the ropes can be calculated
F = 0.577 (1000 N)
= 577 N
= 0.58 kN
The calculators below can be used to calculate wire rope forces. Note that mass (kg) and not weight (N) is used as input.
Friction, load and effort forces acting in ropes turned around bollards.
Force and tension in cables with uniform loads.
Factors of Safety - FOS - are important in engineering designs.
One side of a triangle when the opposite angle and two sides are known.
Minimum breaking strength and safe load of manila 3-strand rope.
Nylon 3-strand and 8-strand rope - minimum breaking strength and safe load.
Polyester Polyolefin dual fiber 3-strand rope - minimum breaking strength and safe load.
Polyester 3-strand and 8-strand rope - minimum breaking strength and safe load.
Polypropylene fiber 3-strand and 8 strand rope - minimum breaking strength and safe load.
Pulleys, blocks and tackles.
Safe loads of shackles.
Sisal rope 3-strand, minimum breaking strength and safe load.
Effort force to raise a load.
6 strand x 19 wire (6x19) - minimum breaking strength, safe loads and weight.
