The increased force or tension in a rope or cable due to angles:
Rope Angle with Load (degrees) | Increased Force or Tension Factor - θ - | |
- α - | - β - | |
0 | 90 | 1.00 |
5 | 85 | 1.00 |
10 | 80 | 1.02 |
15 | 75 | 1.04 |
20 | 70 | 1.07 |
25 | 65 | 1.10 |
30 | 60 | 1.16 |
35 | 55 | 1.22 |
40 | 50 | 1.31 |
45 | 45 | 1.41 |
50 | 40 | 1.56 |
55 | 35 | 1.74 |
60 | 30 | 2.00 |
65 | 25 | 2.37 |
70 | 20 | 2.92 |
75 | 15 | 3.86 |
80 | 10 | 5.76 |
85 | 5 | 11.5 |
As we can see from the table above - with
α = 60 degrees
and
β = 30 degrees
the force or tension F in the rope is doubled.
The force acting in the rope can be calculated as
Frope = θ F (1)
Frope = force acting in the rope (N, lb)
θ = increased force or tension factor from the table above
F = load (N, lb)
The force acting in the horizontal beam can be calculated as
Fbeam = (Frope2 + F2)1/2 (2)
The angle α can be calculated as
α = tan-1(h / d) (3)
α = angle (degrees)
h = vertical distance between horizontal beam and rope (m, ft)
d = length of horizontal beam (m, ft)
The angle β can be calculated as
β = tan-1(d / h) (4)
β = angle (degrees)
Example - Increased Force in a Rope due to Angle
The maximum force in the rope in the figure above can be estimated by firs calculate the angles:
α = tan-1(3.1 / 4.3)
= 35.8o
β = tan-1(4.3 / 3.1)
= 54.2o
From the table above the tension factor is approximately 1.22 and the force in the rope can be calculated as
Frope = (500 kN) 1.22
= 610 kN
Rope Force and Tension Calculator
• Mechanics
• Statics
Bollard Forces
Friction, load and effort forces acting in ropes turned around bollards.
Cable Loads
Force and tension in cables with uniform loads.
Drawbridge - Force and Moment vs. Elevation
Calculate the acting forces and moments when elevating drawbridges or beams.
Equilibrant Force
The force required to keep a system of forces in equilibrium.
Force
Manila Ropes - Strength
Minimum breaking strength and safe load of manila 3-strand rope.
Nylon Ropes - Strengths
Nylon 3-strand and 8-strand rope - minimum breaking strength and safe load.
Polyester Polyolefin Ropes - Strengths
Polyester Polyolefin dual fiber 3-strand rope - minimum breaking strength and safe load.
Polyester Ropes - Strengths
Polyester 3-strand and 8-strand rope - minimum breaking strength and safe load.
Polypropylene Fiber Ropes - Strengths
Polypropylene fiber 3-strand and 8 strand rope - minimum breaking strength and safe load.
Pulleys
Pulleys, blocks and tackles.
Shackles - Safe Loads
Safe loads of shackles.
Sisal Ropes - Strengths
Sisal rope 3-strand, minimum breaking strength and safe load.
Vector Addition
Online vector calculator - add vectors with different magnitude and direction - like forces, velocities and more.
Winches
Effort force to raise a load.
Wire Rope Slings
Wire Ropes - Strengths
6 strand x 19 wire (6x19) - minimum breaking strength, safe loads and weight.
