Polyester Polyolefin Ropes - Strengths
Minimum breaking strength and safe load of polyester polyolefin rope are indicated below.
Rope DiameterMinimum Breaking StrengthSafe Load
(Safety Factor 12)
Weight
(in)(mm)(lbf)(kN)(lbf)(kN)(lbm/ft)(kg/m)
1/4 6 1200 5.34 100 0.445 0.016 0.024
5/16 8 1870 8.3 156 0.693 0.025 0.037
3/8 10 2700 12.0 225 1.00 0.036 0.054
7/16 11 3500 15.6 292 1.30 0.048 0.071
1/2 12 4400 19.6 367 1.63 0.062 0.092
9/16 14 5200 23.1 433 1.93 0.079 0.118
5/8 16 6100 27.1 508 2.26 0.095 0.141
3/4 18 8400 37.4 700 3.11 0.135 0.201
7/8 22 11125 49.5 927 4.12 0.180 0.268
1 24 13175 58.6 1100 4.89 0.218 0.324
1 1/16 26 14775 66 1230 5.47 0.245 0.365
1 1/8 28 16325 73 1360 6.05 0.271 0.403
1 1/4 30 19900 89 1660 7.38 0.334 0.495
1 3/8 32 21950 98 1830 8.14 0.365 0.543
1 1/2 36 28250 126 2350 10.5 0.470 0.699
1 5/8 40 32950 147 2750 12.2 0.550 0.818
1 3/4 44 36850 164 3070 13.7 0.620 0.923
2 48 48050 214 4000 17.8 0.810 1.21
Download and print Polyester Polyolefin Rope Safe Load Chart
Example - Maximum Safe Mass for a 3/8" Polyester Polyolefin Rope
The relationship between mass and force (weight) can be expressed as
m = F / g                              (1)
F = force, weight (N)
m = mass (kg)
g = acceleration of gravity (9.81 m/s2
Maximum safe mass for a 3/8" polyester polyolefin rope where safe load is 1.0 kN can be calculated as
m = (1.0 103 N) / (9.81 m/s2)
   =  102 kg
Miscellaneous
Bollard Forces
Friction, load and effort forces acting in ropes turned around bollards.
Cable Loads
Force and tension in cables with uniform loads.
Manila Ropes - Strength
Minimum breaking strength and safe load of manila 3-strand rope.
Nylon Ropes - Strengths
Nylon 3-strand and 8-strand rope - minimum breaking strength and safe load.
Polyester - Chemical Resistance
Chemical resistance of Polyester to products like Acetic acid, Diesel oil and others.
Polyester Ropes - Strengths
Polyester 3-strand and 8-strand rope - minimum breaking strength and safe load.
Polypropylene Fiber Ropes - Strengths
Polypropylene fiber 3-strand and 8 strand rope - minimum breaking strength and safe load.
Pulleys
Pulleys, blocks and tackles.
Sisal Ropes - Strengths
Sisal rope 3-strand, minimum breaking strength and safe load.
Winches
Effort force to raise a load.
Wire Rope Slings
