Movement Ratio
A machine is a device that can change the magnitude and line of action of a force.
Examples are
  • pulley systems
  • gear systems
  • screw-jacks
A simple machine amplifies the input force (effort) to a larger output force (load).
Movement Ratio
The movement ratio (or velocity ratio) of a machine is defined as the ratio of the distance moved by the effort to the distance moved by the load. Movement ratio can be expressed as
Mr = se / sl
   = velocity ratio                         (1)
Mr = movement ratio
se = distance moved by the effort   (m, ft)
sl = distance moved by the load     (m, ft)
Machine Efficiency
The efficiency of a simple machine is defined as the ratio of the force ratio to the movement ratio and can be expressed as
μ = Fr / Mr                       (2)
μ = machine efficiency
Fr = force ratio
Dynamics
Motion - velocity and acceleration, forces and torque.
Mechanics
Conn-Rod Mechanism
The connecting rod mechanism.
Force Ratio
The force ratio is the load force versus the effort force.
Motors - Speed vs. Pulley Diameter
Pulley (Sheave) selection charts for motors ranging 850 - 3450 rpm.
Pulleys
Pulleys, blocks and tackles.
Ratios and Proportions
The relative values between quantities - ratios and proportions.
Screw Jack - Effort Force vs. Load
Screw jacks and effort forces.
Toggle Joint
A toggle joint mechanism can be used to multiply force.
