For a system with two shafts and two pulleys - as indicated with pulley 1 and 2 in the figure above:
d1 n1= d2 n2 (1)
d1 = driving pulley diameter (inch, mm)
n1 = revolutions of driving pulley (rpm - rounds per minute)
d2 = driven pulley diameter (inch, mm)
n2 = revolutions of driven pulley (rpm - rounds per minute)
Equation (1) can be transformed to express the
n2 = d1 n1 / d2 (2)
n1 = d2 n2 / d1 (3)
d2 = d1 n1 / n2 (4)
d1 = d2 n2 / n1 (5)
For a system a with three shafts and four pulleys - as indicated in the figure above:
n2 = n3 (6)
n4 = n1 (d1 d3) / (d2 d4) (7)
The revolutions of shaft 4 in a multiple belt transmission like indicated in the figure above where
n1 = 1000 rpm
d1 = 100 mm
d2 = 50 mm
d3 = 110 mm
d4 = 60 mm
can be calculated as
n4 =(1000 rpm) (100 mm) (110 mm) / ((50 mm) (60 mm))
= 3667 rpm
Calculate belts power transmission and efficiency
Maximum conveyor belt speed.
Output torque, speed and horsepower with gears.
Gear train transmissions - bicycle gearing.
Gears effort force vs. load force.
Pulley (Sheave) selection charts for motors ranging 850 - 3450 rpm.
Pulleys, blocks and tackles.
