Conveyors - Belt Speed
Typical maximum conveyor belt speeds for products like
  • Grain and Free Flowing Material
  • Mine Coal and Earth
  • Primary Crushed Hard Ores and Stone
are indicated in the charts below:
Miscellaneous
Angles of Repose
Tipping or dumping angles for common materials like ashes, sand, earth, shingles and more.
Belts - Power Transmission and Efficiency
Calculate belts power transmission and efficiency
Belts - Pulley Diameters vs. Speed
The pulley laws - driver and driven - diameter and rpm
Conveyors - Capacities
Calculate conveyor capacities.
Conveyors - Load & Power Consumption
Conveyor required power consumption vs. load.
Conveyors - Maximum Inclination vs. Product
Maximum conveyor inclination slopes for typical products.
Kinetic Energy
Energy possessed by an object's motion is kinetic energy.
Pneumatic Transport and Conveying - Carrying Velocities
Recommended air velocity for pneumatic transport of products like cement, coal, flour and more.
Slurry Transports - Minimum Flow Velocities
Flow velocities in slurry transport systems to avoid settling of solids.
