Belt driven Fans - Fan vs. Motor Speed
Belt driven fans are used in heating, ventilation, air-conditioning and cooling (HVAC) systems.
The speed of a fan wheel versus the speed of the motor with a belt drive can be calculated as
df nf = dm nm (1)
df = pulley diameter fan (inch, mm)
nf = speed of fan (rpm - rounds per minute)
dm = pulley diameter motor (inch, mm)
nm = speed of motor (rpm - rounds per minute)
Example - Speed of Fan
A synchronous electrical motor rotates with speed 1000 rpm. The motor pulley diameter is 76.5 mm and the fan pulley diameter is 205.5 mm. The speed of the fan can be calculated by modifying (1) to
nf = dm nm / df
- or with values:
nf = (76.5 mm) (1000 rpm) / (205.5 mm)
= 372 rpm
• Ventilation
Efficiency of Small Machine Elements
Friction and efficiency in bearings and roller chains.
Fan Motors - Starting Torques
The motor must be capable of accelerating the fan wheel to it's operating speed.
Fans - Troubleshooting
Guide to troubleshooting fan problems.
Motors - Speed vs. Pulley Diameter
Pulley (Sheave) selection charts for motors ranging 850 - 3450 rpm.
Pulleys
Pulleys, blocks and tackles.
