Sound - Room Attenuation in Direct Sound Fields
Room attenuation in a direct sound field as function of room size and room sound absorption characteristics:
  • 1 ft2 = 0.0929 m2
The diagram is based on a listener within 5 ft (1.5 m) from the source.
Typical Rooms and their Absorption Characteristics
  • Hard - bath rooms, large churches, gymnasiums, factories
  • Average - private homes, concert halls, restaurants, offices, conference rooms, hotel rooms, school rooms, hospitals,  libraries, churches, reception rooms
  • Soft - radio and TV studios, theaters
Example - Sound Attenuation in an "Average" Room
The sound attenuation in an "average" room with surface 100 m2 (1076 ft2) can be estimated from the diagram above to be approximately
5 dB
Acoustics
Propagation of Sound Indoors - the Room Constant
In a room the sound or noise will reach the receiver as direct and reverberant sound.
Sound - Attenuation and Speed vs. Sound Frequency and Air Humidity
The speed and attenuation of sound in moist air varies with sound frequency and air humidity.
Sound - Attenuation and the Directivity Coefficient
The attenuation in a room depends on the location of the sound source and the receiver - and the room constant.
Sound - Reverberation Time
The sound reverberation time indicates how long it takes until the sound pressure level in a room is decreased with 60 dB.
Sound - Room Absorption Characteristics
Mean absorption coefficients and reverberation times in typical rooms.
Sound - Room Absorption Coefficients
Room sound absorption and absorption coefficients for common materials like plaster walls, brickwork, plywood panels and more.
Sound Pressure
