Sound - Room Absorption Coefficients
The sound absorption coefficient is the ratio of absorbed sound intensity in an actual material to the incident sound intensity and can be expressed as
α = Ia / Ii                                (1)
α = sound absorption coefficient
Ia = sound intensity absorbed  (W/m2)
Ii = incident sound intensity  (W/m2)
 Absorption coefficient - α - for some common materials can be found in the table below:
MaterialSound Absorption
Coefficient 1)
- α -
Acoustic belt, 12 mm 0.5
Acoustic tiles 0.4 - 0.8
Asbestos, sprayed 25 mm 0.6 - 0.7
Brickwork, painted 0.01 - 0.02
Brickwork, unpainted 0.02 - 0.05
Carpet, heavy on concrete 0.3 - 0.6
Carpe, heavy on foam rubber 0.5 - 0.7
Concrete block, coarse 0.3 - 0.4
Concrete block, painted 0.05 - 0.07
Cork sheet, 6 mm 0.1 - 0.2
Fiberboard on battens, 12 mm 0.3 - 0.4
Floor, concrete or terrazzo 0.02
Floor, linoleum, asphalt, rubber or cork tiles on concrete 0.03
Floor, wood 0.06 - 0.1
Hardwood 0.3
Glass, large panes heavy plate 0.03 - 0.05
Glass, ordinary windows 0.1 - 0.2
Gypsum board, 12 mm 0.04 - 0.07
Mineral wool, 100 mm 0.65
Persons, each 0.2 - 0.5
Plaster walls 0.01 - 0.03
Plywood panel, 3 mm 0.01 - 0.02
Polystyrene, expanded on 50mm battens 0.35
Polystyrene, expanded rigid backing 0.15
Polyurethane foam, flexible 0.95
Rubber sheet, 6 mm porous 0.1 - 0.2
Slag wool or glass silk, 50 mm 0.8 - 0.9
Snow 0.75
Wood wool cement on battens, 25 mm 0.6 - 0.07
1) Note! - the sound absorption coefficient varies with frequency.
Download and print Room Sound Absorption Coefficient chart
Total Room Sound Absorption
The total sound absorption in a room can be expressed as
A = S1 α1 + S2 α2 + .. + Sn αn
   = ∑(Si αi)                                            (2)
A = the absorption of the room (m2 Sabine)
Si = area of the actual surface (m2)
αi = absorption coefficient of the actual surface
Mean Absorption Coefficient
The mean absorption coefficient for the room can be expressed as:
αm = A / S                                 (3)
αm = mean absorption coefficient
S = total surface in the room (m2)
The acoustic characteristics of a room can be calculated with the formulas above, or estimated for typical rooms.
Example - Room Acoustic Absorption
The total sound absorption in a room with
  • 10 m2 concrete floor with absorption coefficient 0.02
  • 10 m2 concrete roof with absorption coefficient 0.02
  • 40 m2 fiberboard walls with absorption coefficient 0.3
can be calculated as
A = (10 m2) (0.02) + (10 m2) (0.02) + (40 m2) (0.3)
   = 12.2 m2 Sabine
The mean absorption coefficient can be calculated as
αm = (12.2 m2 Sabine) / ((10 m2) + (10 m2) + (40 m2))
     = 0.2
Acoustics
Noise and Attenuation
Propagation of Sound Indoors - the Room Constant
In a room the sound or noise will reach the receiver as direct and reverberant sound.
Sound - Reverberation Time
The sound reverberation time indicates how long it takes until the sound pressure level in a room is decreased with 60 dB.
Sound - Room Absorption Characteristics
Mean absorption coefficients and reverberation times in typical rooms.
Sound - Room Attenuation in Direct Sound Fields
Room size, absorption characteristics - and attenuation in direct sound fields.
