Sound - Reverberation Time
Reverberant sound is the collection of all reflected sounds.
The Reverberation Time - Ta - for a room is the time it takes before the sound pressure level has decreased with 60 dB after the sound source is terminated and can be calculated as
Mean sound absorption coefficient αm <= 0.35:
Ta = 0.16 V / A                     (1)
Ta = reverberation time (s)
V = room volume (m3)
A = the total sound absorption of the room (m2 Sabine)
Download and print Sound Reverberation Time chart
Mean sound absorption coefficient αm > 0.35:
Ta = 0.16 V / [(A /αm)ln (1 / (1 - αm))]                       (2)
Note! The sound absorption of the room - A - vary with sound frequency, and so do the reverberation time - Ta.
Recommended Sound Reverberation Times for some typical Rooms
Recommended Reverberation Time - Ta - (s)
Room Volume
(m3)
Conference room, school, cinemaConcert Hall, Normal MusicChurch, Organ Music
10000 1.0 1.5 2.0
1000 0.8 1.3 1.6
100 0.6 1.1 1.2
Example - Sound Reverberation Time for a Room
The sound reverberation time for a room with mean sound absorption coefficient 0.2, total sound total sound absorption 12.2 m2 Sabine and room volume 4 m3 - can be calculated with equation (1) as
Ta = 0.16 (4 m3) / (12.2 m2 Sabine)
    = 0.05 s
Acoustics
Room acoustics and acoustic properties, decibel A, B and C, Noise Rating (NR) curves, sound transmission, sound pressure, sound intensity and sound attenuation.
Propagation of Sound Indoors - the Room Constant
In a room the sound or noise will reach the receiver as direct and reverberant sound.
Sound - Room Absorption Characteristics
Mean absorption coefficients and reverberation times in typical rooms.
Sound - Room Absorption Coefficients
Room sound absorption and absorption coefficients for common materials like plaster walls, brickwork, plywood panels and more.
Sound - Room Attenuation in Direct Sound Fields
Room size, absorption characteristics - and attenuation in direct sound fields.
