- Ta -
The mean sound absorption coefficient should be calculated when more accurate values are needed.
The diagram below can be used to determine the sound absorption in rooms of different sizes and with different accoustic characteristics.
Room acoustics and acoustic properties, decibel A, B and C, Noise Rating (NR) curves, sound transmission, sound pressure, sound intensity and sound attenuation.
In a room the sound or noise will reach the receiver as direct and reverberant sound.
The sound reverberation time indicates how long it takes until the sound pressure level in a room is decreased with 60 dB.
Room sound absorption and absorption coefficients for common materials like plaster walls, brickwork, plywood panels and more.
Room size, absorption characteristics - and attenuation in direct sound fields.
