Noise Attenuation in Chambers
Noise attenuation in a chamber:
dL = 10 log( 1 / Ao (cos(θ) / 2 π s2  + (1 - α) / (α A)))                              (1)
dL = sound attenuation (dB)
Ao = outlet area (m2)
A = chamber inside surface area (m2)
θ = angle between inlet and outlet (degrees)
s = distance between inlet and outlet (m)
α = inside surface sound absorption coefficient
Example - Attenuation in a Chamber
The attenuation in a chamber lined with mineral wool with a sound absorption coefficient α = 0.65, inside surface area A = 16 m2, outlet area Ao = 0.25 m2, distance between inlet and outlet s = 2 m, angle between inlet and outlet α = 45o, can be calculated as
dL = 10 log( 1 / (0.3 m2) (cos(45o) / 2 π (2 m)2  + (1 - 0.65) / (0.65 (16 m2))))
    = 17.3 dB
Noise and Attenuation
Change in Duct Area and Noise Attenuation
Sound attenuation vs. change in duct size.
Sound - Attenuation and Speed vs. Sound Frequency and Air Humidity
The speed and attenuation of sound in moist air varies with sound frequency and air humidity.
