Pressure Units Converter
Cnvert gas pressures between kPa, psi, incheswater or inchesmercury:
Eqiuivalent Pressure Units Converter
kPaWater
(inches)
Mercury
(inches)
Pound per square inch
(psi)
0.002 0.01 0.0007 0.00036
0.05 0.2 0.015 0.0072
0.07 0.3 0.022 0.0108
0.10 0.4 0.029 0.0145
0.12 0.5 0.037 0.0181
0.15 0.6 0.044 0.0217
0.17 0.7 0.051 0.0253
0.19 0.8 0.059 0.0289
0.22 0.9 0.066 0.0325
0.25 1.0 0.074 0.036
0.3 1.4 0.100 0.049
0.4 1.7 0.128 0.061
0.5 2.0 0.147 0.072
0.72 2.8 0.203 0.100
0.76 3.0 0.221 0.109
1.0 4.0 0.294 0.144
1.2 5.0 0.368 0.181
1.5 6.0 0.442 0.217
1.7 7.0 0.515 0.253
2.0 8.0 0.588 0.289
2.2 9.00 0.662 0.325
2.5 10 0.74 0.361
2.7 11 0.81 0.397
3.0 12 0.88 0.433
3.2 13 0.96 0.469
3.37 13.6 1.00 0.491
3.4 13.9 1.02 0.500
3.5 14 1.06 0.505
3.7 15 1.10 0.542
4.0 16 1.18 0.578
4.2 17 1.25 0.614
4.5 18 1.33 0.650
4.7 19 1.40 0.686
5.0 20 1.47 0.722
6.2 25 1.84 0.903
6.7 27.2 2.00 0.975
6.9 27.7 2.03 1.000
Download kPa to bar, psi, mmH2O and inH2O chart
Gases and Compressed Air
Pressure
