Pumping Water - Required Horsepower
Energy imparted to water by the pump is called water horsepower - and can be calculated as
Pwhp = q h SG / (3960 μ)                            (1)
Pwhp = water horsepower (hp)
q = flow (gal/min)
h = head (ft)
SG = 1 for water Specific Gravity
μ = pump efficiency (decimal value)
Horsepower can also be calculated as:
Pwhp = q dp / (1715 μ)                   (2)
dp = delivered pressure (psi)
Example -  Horsepower Required to Pump Water
20 gallons of water per minute is elevated 20 ft. The horsepower required (ex. friction loss in piping and efficiency = 1.0) can be calculated as
Pwhp = (20 gpm) (20 ft) (1) / (3960 (1.0))
        = 0.10 hp
Power required to pump water at 60oF with ideal pump efficiency 1.0:
Pumping Water - Power vs. Head and Flow
Volume Flow
(gpm)
Power (hp)
Height (ft)
51015202530354050
5 0.00631 0.0126 0.0189 0.0253 0.0316 0.0379 0.0442 0.0505 0.0631
10 0.0126 0.0253 0.0379 0.0505 0.0631 0.0758 0.0884 0.101 0.126
15 0.0189 0.0379 0.0568 0.0758 0.0947 0.114 0.133 0.152 0.189
20 0.0253 0.0505 0.0758 0.101 0.126 0.152 0.177 0.202 0.253
25 0.0316 0.0631 0.0947 0.126 0.158 0.189 0.221 0.253 0.316
30 0.0379 0.0758 0.114 0.152 0.189 0.227 0.265 0.303 0.379
35 0.0442 0.0884 0.133 0.177 0.221 0.265 0.309 0.354 0.442
40 0.0505 0.101 0.152 0.202 0.253 0.303 0.354 0.404 0.505
45 0.0568 0.114 0.170 0.227 0.284 0.341 0.398 0.455 0.568
50 0.0631 0.126 0.189 0.253 0.316 0.379 0.442 0.505 0.631
60 0.0758 0.152 0.227 0.303 0.379 0.455 0.530 0.606 0.758
70 0.0884 0.177 0.265 0.354 0.442 0.530 0.619 0.707 0.884
80 0.101 0.202 0.303 0.404 0.505 0.606 0.707 0.808 1.01
90 0.114 0.227 0.341 0.455 0.568 0.682 0.795 0.909 1.14
100 0.126 0.253 0.379 0.505 0.631 0.758 0.884 1.01 1.26
Note! Individual pump curves should always be used for exact calculations.
Power Consumption in Metric Units
The power consumption for pumping water can be expressed in metric units as
P = q h ρ / (6116 103 μ)                            (3)
P = power (kW)
q = flow (liter/min)
h = head (m)
ρ = density (kg/m3) (water 1000 kg/m3)
Example - Power Required to Pump Water
The power required to pump 100 l/min water an elevation of 10 m (ex. friction loss in piping and efficiency = 1.0) can be calculated as
  P = (100 liter/min) (10 m) (1000 kg/m3) / (6116 103 (1.0))
     = 0.16 kW
Pumps
Centrifugal Pumps
Efficiency in Pumps or Fans
The overall pump and fan efficiency is the ratio power gained by the fluid to the shaft power supplied.
Hydropower
Power potential vs. head and flow rate.
Positive Displacement Pumps
Introduction tutorial to positive displacement pumps basic operating principles.
Power
Power Gained by Fluid from Pump or Fan
Calculate the power gained by fluid from an operating pump or fan.
Pump Power Calculator
Pumping Water - Energy Cost Calculator
Calculate the energy cost of pumping water.
Pumps - Affinity Laws
Turbo machines affinity laws can be used to calculate volume capacity, head or power consumption in centrifugal pumps when changing speed or wheel diameters.
Pumps - Head vs. Pressure
Converting head (ft or m) to pressure (psi or bar, kg/cm2) and vice versa.
Pumps - NPSH (Net Positive Suction Head)
An introduction to pumps and the Net Positive Suction Head (NPSH).
Pumps - Parallel vs. Serial Arrangement
Adding head and flowrate for pumps arranged in parallel vs. serial.
Calculate specific work done by pumps, fans, compressors or turbines.
Water Pump Calculator
Water pump calculations.
