Water Pump Calculator
Calculate Pressure Head, Total Dynamic Head, Bowl Horsepower, Total Trust acting on Driver Thrust Bearing, Field Head, Power Loss due to Shafting, Power Loss in Thrust Bearings, Motor Load, Field Efficiency, Input Horsepower (Power Supplied to Driver) and Shaft Elongation.
http://www.engineeringtoolbox.com/horsepower-d_472.html
Pumps
Pumping Water - Required Horsepower
Horsepower required to pump water.
