Centrifugal Pumps - Shut-Off Head
The maximum "shut-off" head for a centrifugal pump can be estimated as
hs = (d n / 1840)2 (1)
h = head (feet)
d = outside diameter impeller (inches)
n = wheel velocity - revolution per minute - (rpm)
• Pumps
Centrifugal Pump Standards
International centrifugal pump design and dimension standards.
Centrifugal Pumps
Centrifugal Pumps - Influence of Viscosity
Hydrodynamic losses through pumps depends on fluid viscosities.
Centrifugal Pumps - Minimum Flow
Minimum continuous flow to prevent flashing in centrifugal pumps.
Centrifugal Pumps - Speed Torque Curve
The characteristic speed torque curves for centrifugal pumps.
Pump Power Calculator
Pumps - Affinity Laws
Turbo machines affinity laws can be used to calculate volume capacity, head or power consumption in centrifugal pumps when changing speed or wheel diameters.
