Centrifugal Pumps - Speed Torque Curve
The speed torque curve characterize a centrifugal pump. The theoretical characteristic is a parabola starting from the origin and proportional to the square of the speed.
The torque can be expressed as
T = k n2                                   (1)
T = torque (Nm, lbf ft)
k = constant
n = pump speed or velocity (rpm)
With the discharge valve closed the torque amounts to 30 - 50 % of the nominal torque at full speed.
Full Load Torque
The torque at full load can be calculated as
T = 30 P / (π n)                                  (2)
T = torque (kN m)
P = power (kW)
Pumps
Centrifugal Pumps
Centrifugal Pumps - Minimum Flow
Minimum continuous flow to prevent flashing in centrifugal pumps.
Centrifugal Pumps - Shut-Off Head
Centrifugal pumps and maximum shut-off head.
Electric Motors - IEC and NEMA Standard Torques
IEC and NEMA torque classifications of electrical motors.
Pumps - Classifications
Centrifugal pumps vs. positive displacement pumps.
