Single Phase Power Equations
Single phase power equations:
Real Power
Wapplied = U I PF / 1000                             (1)
Wapplied = real power (kilowatts, kW)
U = voltage (volts, V)
I = current (amps, A)
PF = power factor - 0.7 - 1
Total Power
W = U I / 1000                                     (2)
Brake Horsepower
  • Brake horsepower is the actual power delivered to or by a shaft.
WBHP = U I PF μ / 746                          (3)
WBHP = brake horsepower (hp)
μ = device efficiency
Example - Horsepower vs. Current and Voltage
An AC motor consumes 8 amps of current. The voltage supplied is 12 V, the efficiency of the system is 96% (0.96) and the power factor is 1. The horsepower can then be calculated as
WBHP = (12 V) (8 A) (1) (0.97) / 746
         = 0.125 HP
         ≈ 1/8 HP
Electrical
AC - Active, Reactive and Apparent Power
Real, imaginary and apparent power in AC circuits.
Aluminum Conductor Characteristics
Characteristics of all-aluminum conductors (AAC).
Electric Motors - Efficiency
Electrical Formulas
Commonly used electrical formulas like Ohms Law and more.
Electrical Motor Calculator: Power, Efficiency & Torque Calculations
Calculate amps, hp and kVA for electrical motors.
Electrical Motors - Shaft Power vs. Voltage and Current
Calculate electric motors shaft power.
Electrical Vehicle Charging - Power vs. Voltage and Amps
EV Charging - AC vs. DC, single phase vs. three phase and power vs. voltage and amps.
Measurement of Electrical Power
Measure electric power with an ammeter and a voltmeter.
Power
Power Wiring - Color Codes
Color codes used in power wiring.
Single and Three Phase AC - Electric Current vs. Power
Convert between single phase (120, 240 and 480 Voltage) and three phase (240 and 480 Voltage).
Three-Phase Electrical Motors - Power vs. Amps and Voltage
Full load amps, wire and conduit sizes for three phase electrical motors.
Three-Phase Power - Equations
Electrical 3-phase equations.
