Three-Phase Power - Equations
Most AC power today is produced and distributed as three-phase power where three sinusoidal voltages are generated out of phase with each other. With single-phase AC power there is only one single sinusoidal voltage.
Real Power
Line to line voltage:
Wapplied = 31/2 Ull I cos(Φ)
= 31/2 Ull I PF (1)
Wapplied = real power (W, watts)
Ull = line to line voltage (V, volts)
I = current (A, amps)
PF = cos Φ
= power factor (0.7 - 0.95)
Line to neutral voltage:
Wapplied = 3 Uln I cos(Φ) (2)
Uln = line to neutral voltage (V, volts)
For pure resistive load: PF = cos Φ = 1
- resistive loads converts current into other forms of energy, such as heat
- inductive loads use magnetic fields like motors, solenoids, and relays
Power Factor
Typical power factors:
| Device | Power Factor |
| Lamp, fluorecent uncompensated | 0.5 |
| Lamp, fluorecent compensated | 0.93 |
| Lamp, incandescent | 1 |
| Motor, induction 100% load | 0.85 |
| Motor, induction 50% load | 0.73 |
| Motor, induction 0% load | 0.17 |
| Motor, synchronous | 0.9 |
| Oven, resistive heating element | 1 |
| Oven, induction compensated | 0.85 |
| Pure resistive load | 1 |
Example - Pure Resistive Load
For pure resistive load and power factor = 1 the real power in a 400/230 voltage (line to line / line to neutral) 20 amps circuit can be calculated as
W applied = 3 1/2 (400 V) (20 A) 1
= 13856 W
= 13.9 kW
Total Power
W = 31/2 U I (2)
Brake Horsepower
- Brake horsepower is the actual power delivered to or by a shaft.
WBHP = 31/2 U I PF μ / 746 (3)
WBHP = brake horse power (hp)
μ = device efficiency
• Electrical
AC - Active, Reactive and Apparent Power
Real, imaginary and apparent power in AC circuits.
AC Circuits - Power vs. Voltage and Current
The alternating current In an AC circuit is generated by a sinusoidal voltage source.
Aluminum Conductor Characteristics
Characteristics of all-aluminum conductors (AAC).
Electric Motors - Efficiency
Electrical Equipment - Power Consumption
Typical power consumption and running time for common electrical equipment.
Electrical Formulas
Commonly used electrical formulas like Ohms Law and more.
Electrical Induction Motors - Slip
Slip is the difference between an electrical induction motor's synchronous and asynchronous speed.
Electrical Motors - Service Factors
Service factor - SF - is a measure of periodically overload capacity at which a motor can operate without beeing damaged.
Electrical Motors - Shaft Power vs. Voltage and Current
Calculate electric motors shaft power.
Electrical Vehicle Charging - Power vs. Voltage and Amps
EV Charging - AC vs. DC, single phase vs. three phase and power vs. voltage and amps.
Law of Cosines
One side of a triangle when the opposite angle and two sides are known.
Measurement of Electrical Power
Measure electric power with an ammeter and a voltmeter.
Power
Single Phase Power Equations
Power equations for single phased electrical systems.
