No. Poles
Electrical units, amps and electrical wiring, wire gauge and AWG, electrical formulas and motors.
Operating speed of an induction motor depends on the input power frequency and the number of magnetic poles in the motor.
Full load operating torque vs. break down, pull up and locked rotor torque.
