Electrical Motors - Heat Loss
Heat Loss from Electric Motors during Operation
Heat loss from electric motors due to inefficiency:
Size of Motor (kW) | Efficiency (%) | Heat Loss (watts/kW) |
0 - 2 | 75 | 250 |
3 - 15 | 85 | 150 |
15 - 150 | 90 | 100 |
150 - | 92 | 80 |
- 1 kW = 1.34 hp
- 1 hp = 0.746 k W
Example - Heat Loss from an Electric Motor
The heat loss from an electric motor supplied with 10 kW can with the heat loss 150 watts/kW from the table above be calculated as
(10 kW) (150 watts/kW)
= 1500 watts
= 1.5 kW
The rest of the energy
(10 kW) - (1.5kW)
= 8.5 kW
is output mechanical energy.
If the motor and the mechanical equipment connected to the motor is in the same room - or enclosure - all electric energy supplied to the motor will convert to heat and temperature increase in the room.
Heat Loss from an Electric Driven Device to a Room
The heat transferred to a room or enclosure depends on the location of the motor and the driven device related to the room.
- motor and driven device in the room - all energy to the motor is at the end transferred to the room (heat loss from the motor and frictional energy from the driven device)
- motor in the room and device outside the room - only heat loss from the motor is transferred to the room - frictional energy from the driven device is lost outside the room
- motor outside the room and device inside the room - frictional loss from the driven device is transferred to the room - energy loss from the electric motor is lost outside the room
Nameplate Rating (hp) | Motor Efficiency (%) | Heat Loss to Room Air (Btu/hr per rated hp) | ||
Motor in Room Driven Device inside Room | Motor in Room Driven Devise Outside Room | Motor Outside Room Driven Device inside Room | ||
0 - 1.5 | 0.80 | 2542 | 508 | 2034 |
1.5 - 12.5 | 0.85 | 2542 | 381 | 2161 |
12.5 - | 0.90 | 2542 | 254 | 2289 |
- 1 Btu/h = 0.293 W
- 1 horsepower = 2542 Btu/hr
• Electrical
Electric Motors - Efficiency
Fan Motors - Starting Torques
The motor must be capable of accelerating the fan wheel to it's operating speed.
Heat Gain from Electrical Motors in Continuous Operation
Amount of heat transferred from electrical motor to ambient room vs. locations of fan and motor.
Heat Losses from Electrical Equipment
Heat loss from electrical equipment like switch-gear, transformers and variable frequency drives.
Three-Phase Electrical Motors - Power vs. Amps and Voltage
Full load amps, wire and conduit sizes for three phase electrical motors.
