Electric Cable Size vs. Current Rating
The table below indicates current ratings for fixed cable installations within buildings. The table is based on PVC-wiring and PVC-insulated cables - single wire, fine wires and multi stranded wires.
Electric Cables - Current Ratings
Installation MethodA1A2B1B2
InstallationSingle core cables, in insulating tubes, in thermally insulated wallsMulti core sheathed cables, in insulating tubes, in thermally insulated wallsSingle core cables, in insulating tubes, on wallsMulti core cables, or multi core sheathed cables, in insulating tubes, on walls
Number of Cores
23232323
Cross-Section
(mm2)
Current Ratings
(ampere)
1.5 15.5 13.5 15.5 13.0 17.5 15.5 16.5 15.0
2.5 19.5 18.0 18.5 17.5 24 21 23 20
4 26 24 25 23 32 28 30 27
6 34 31 32 29 41 36 38 34
10 46 42 43 39 57 50 52 46
16 61 56 57 52 76 68 69 62
25 80 73 75 68 101 89 90 80
35 99 89 92 83 125 110 111 99
50 119 108 110 99 151 134 133 118
70 151 136 139 125 192 171 168 149
95 182 164 167 150 232 207 201 179
120 210 188 192 172 269 239 232 206
150 240 216 219 196
185 273 245 248 223
240 320 286 291 261
300 367 328 334 298
  • operating temperature max. 70 oC
  • ambient temperature max. 70 oC
  • A1 - Single core cables in a conduit in a thermally insulated wall
  • A2 - Multi core cable or multi-core sheathed cable in a conduit in a thermally insulated wall
  • B1 - Single core cables in conduit or wall
  • B2 - Multi core cable or multi-core sheathed cable in a conduit in a wall
Electrical
12 Volt - Amps Amps vs. Wire Gauge: Choosing the Right Wire Size
Maximum current (amps) in a 12V electrical circuit vs. size (AWG) and length of wire.
Aluminum Conductor Characteristics
Characteristics of all-aluminum conductors (AAC).
AWG - American Wire Gauge vs. Circular Mils
AWG vs. diameter mil, circular mil, diameter in mm and area in mm2.
AWG - Wire Gauge Sizes: Current Ratings, Charts, Measurements, and Conversion Guide
Amp ratings vs. US AWG wire gauge.
AWG Wire Gauge Chart & Table – American Wire Gauge (AWG) Standards
The AWG (American Wire Gauge) wire size chart with detailed specifications on wire diameter, resistance, and ampacity. Find conversions between AWG sizes and metric units for electrical and engineering applications.
Electric Wire - Calculating Cross-Section Areas
Calculate single and bunched electric wire cross-section area and diameter.
Electrical Motors - Maximum Cable Size and Length vs. Power
Maximum electrical motor cable length vs. power.
Power Wiring - Color Codes
Color codes used in power wiring.
Three-Phase Electrical Motors - Power vs. Amps and Voltage
Full load amps, wire and conduit sizes for three phase electrical motors.
