Electric Wire - Calculating Cross-Section Areas
Cross-Section Area of Single Wire
The cross-section area of a round single wire can be calculated as
A = D 2 π / 4
= 0.7854 D 2
A = cross-section area (mm 2 , in 2 )
D = diameter (mm, in)
Cross-Section Area Calculator - Single Wire
Cross-Section Area of Bunched Wire
The cross-section area of bunched wires can be calculated as
A = n d 2 π / 4
= 0.7854 n d 2
n = number of wires
d = single wire diameter (mm, in)
Cross-Section Area Calculator - Multiple Wires
Diameter of a Single Wire Cross-Section Area
The diameter of a single wire cross-section area can be calculated as
D = (A 4 / π ) 1/2
= (1.2732 A ) 1/2
Electrical
Electrical units, amps and electrical wiring, wire gauge and AWG, electrical formulas and motors.
AWG - American Wire Gauge Current Ratings
Amp ratings vs. US AWG wire gauges.
AWG - American Wire Gauge vs. Circular Mils
AWG vs. diameter mil, circular mil, diameter in mm and area in mm2.
Electric Cable Size vs. Current Rating
Amps vs. cable size for fixed installations in buildings.
Electric Circuits Voltage Drop
Ohm's law and voltage drop in electric circuits.
Electric Wire - Resistance
Electric resistance in wire made of Copper, Aluminum, Brass, Constantan, Nichrome, Platinum, Silver or Tungsten.
