Lead-Acid Batteries
Voltage and Specific Gravity vs. State of Charge - SOC
Acid specific gravity and charge level in a lead acid battery:
Download and print Lead Acid Battery State of Charge chart
  • overcharged for specific gravity above 1.30
  • very low capacity for specific gravity ranging 1.13 - 1.15
  • discharged for specific gravity below 1.12
Battery Efficiency vs. Temperature
Temperature and lead-acid battery efficiency:
Specific Gravity vs. Temperature
Specific gravity in a fully charged lead acid battery vs. temperature:
Miscellaneous
12 Volt - Amps Amps vs. Wire Gauge: Choosing the Right Wire Size
Maximum current (amps) in a 12V electrical circuit vs. size (AWG) and length of wire.
Electrical Formulas
Commonly used electrical formulas like Ohms Law and more.
Electrical Resistance in Serial and Parallel Networks
Resistors in parallel and serial connections.
Electrical Series Circuits
Voltage and current in electrical series circuits.
Energy Storage Density
Energy density - by weight and volume - for some ways to store energy
Rechargeable Batteries - Properties and Life Calculator
Properties of rechargeable batteries and accumulators.
